tex_wardfan's avatar
tex_wardfan
Air conditioner freezing up question
My trailer has an airxcel 48000 series roof top unit. My question is have any of you, who have this unit, had any problems with the evaporator icing up? I did not need to use the unit on our first trip but I'm sure I will have to on the next. The guy who made our trailer ready and gave us the walk through said we should always run the unit at max cool to keep it from icing up. I read the owners manual for the unit and this doesn't seem correct. It seems like that would make it ice up. Any thoughts on this would be appreciated.
  • Old-Biscuit wrote:
    MAX COOL.....
    Just means uses High Fan Speed vs Low Fan Speed
    Low air flow
    Dirty evap coil
    Dirty return filter
    High Humidity
    All conditions that will cause a perfectly functioning A/C Unit to Ice Up
    X2, clean filter, coils and run fan on high. If that doesn't correct it seek professional help
    MAX COOL.....
    Low air flow
    Dirty evap coil
    Dirty return filter
    High Humidity
    The #1 reason A/C units ice up is low on freon!
  • MAX COOL.....
    Low air flow
    Dirty evap coil
    Dirty return filter
    High Humidity
  • The compressor runs at only one speed and gets the coils cold. Moving more air over them will keep the coils less likely to ice up. In high humidity this can be a problem but low humidity it may not be a problem on any setting.
