jmcgsd wrote:
ChooChooMan74 wrote:
If your starcraft has a 30amp main breaker on your panel, then you are fine. Anything over 30 amps will trip that breaker. If, for some strange reason, you don't have a 30 amp main, then don't use it. My friend's coleman popup has a 30 amp plug that has no main breaker. Just a 20 amp for his ac and 15 amp for his outlets/converter. In reality, he could draw 35 amps on his 30 amp cord if he is connected to a 50 amp outlet.
That's a bit misleading. 50A service is 240v service (two 120v legs) the adapter picks off one of those two legs. The main breaker on your panel only protects from an overload in the rig. Believe me, plug a 120v appliance into a 240v circuit and the sparks will fly!
Use the adapter in confidence and read this for more info.
Where did I say something misleading. I use a 50a to 30a adapter on my rig, so I know how it works. All I said that there are a handful of campers out there that DO NOT HAVE A MAIN BREAKER. On those campers, I wound not advise to use a 50a to 30a adapter because you could potentially overload the cord.
