WA7NDD
May 10, 2014Explorer
Matt_Colie wrote:
James,
Brake fluid and hoses are often ignored at great peril. It is pretty much the same with all the other rubber parts. And while you are changing out the radiator hoses, it is a good idea to replace and coolant and maybe even flush the cooling system. The glycol does not wear out or age, but the corrosion inhibitors sure do.
Matt
Matt, all the fluids, rubber, and hoses are new. As long as the V10 does not blow a plug, all should be fine. Be out on the Oregon Coast for two weeks fist of June. I also forgot to list a new dash camera which works very well, just in case someone does something stupid in front of us.
Jim
About RV Newbies
