- uncle_tExplorera bit of talk here about dragging a hose thru your coach. anyone besides me have a bathroom window?
- mlts22Explorer III wish more black water tanks had a way to access them. One European motorhome I looked at had 8 inch circular access panels that one could turn, then go at the black and gray tanks with a scraper and a wet/dry vac to get anything and everything out.
- NorCal_DanExplorerComplete waste of money...better to use lots of water and dump when full. I use Happy Camper or bio chemicals once or twice a year to keep my sensors reading correctly. You just add the chemicals after emptying the tank, use until full, and dump as normal.
- Carb_CleanerExplorerApparently, on occasion, I have too much time on my hands.
It works pretty good for our straight-shot-to-the-tank toilet. At the least, it makes me feel better about the process, somehow.
The cheaper, red rubber plungers may work better than the fancy unit I used. Besides enlarging the hole for the wand, I had to cut the lower portion off of it to permit a closer proximity to the hole while rinsing.
- atreisExplorerMy trailer came with one and I've never used it. My sensors on black and gray stopped working the first year I had the trailer, but I've found they're not really necessary. (When freshwater is empty, it's time to empty the gray too. Black we've never even come close to filling.)
I do pop the rocks out of my tires though. Gives me something to do after work. :) - carp65ExplorerWe are full-timers and have always used the rotating wand purchased at
Camp World. To me, this does the best job in cleaning a black tank. A small
amount of cheap laundry soap after cleaning also helps. - Bucky_BadgerExplorer
dodge guy wrote:
TyroneandGladys wrote:
Fresno Tundra Driver wrote:
Are they worth it? Yes,for people with OCD. For everyone else just always use plenty of water and you'll be ok.
X2
Nothing to do with OCD! everything to do with proper maintenance! OCD would be coming home from a trip and popping the little rocks out of your tire treads!
So true dodge guy - BumpyroadExplorer
Gene&Ginny wrote:
dodge guy wrote:
They are free protein and already precooked to 185 degrees F.
Don't tell me you also clean the dead bugs from the radiator?!!! ;)
you've gotta get them fresh so they are nice and crispy.
bumpy - Gene_GinnyExplorer
Don't tell me you also clean the dead bugs from the radiator?!!! ;) - dodge_guyExplorer II
Bumpyroad wrote:
wait a minute. do you mean that everybody doesn't do this?
bumpy
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
