GMT830
May 22, 2014Explorer
One of the easiest ways to keep the black tank under control is to let if fill as much as possible before dumping. That will allow the solids to soften and breakdown as much as possible.
If you are just doing weekends and don't use the toilet much and have another trip planned soon, just leave it and dump next time. If you must dump, hold the toilet fill valve open and let the tank fill while you are doing other chores packing up to to go. When we left our last trip of last season I wentso far as to tip the trailer sideways and uphill to get a thorough drain. After the initial drain I closed the valve and put another 15-20 gallons water in and rinsed again. It was pretty clean by that point.
Do not add bleach to the tank, especially mid-season. It will kill the bacteria and slow down the breaking of solids.
I will repeat it again though, don't drain the black tank until it's full. Save you all kinds of problems
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
