LarryJM
May 22, 2014Explorer II
downtheroad wrote:BarneyS wrote:
In my opinion, the "down the toilet wand" is the best way to really get all the "stuff" out of your black tank.
Barney
Even though we have a factory installed black tank flush, I have to agree with this. The down the toilet wand does a better job..
Downside is you have to drag a hose through you rig. and it's best if your toilet is a straight drop to the tank.
I also agree and I'm fortunate in that I just pull the hose in thru the bathroom window which is on the utility side of the trailer to start with so no hoses running thru the rig. I also use the following and think it's about the best you can do since it's flexible on one end and the rotating sprayer really gets the sides and areas clean. It will also bust up the "mound of gloom" if you encounter it.
Larry
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
