- poppin_freshExplorer
wanderingbob wrote:
I have never understood why you feel that your black tank must be so dern clean .
This site has spent many ,many hours discussing this . Why must it be scrubbed out when dumping . I know not , but hurry up cause I have got to use it .
I like to know that if I had too in an emergency, my black tank is clean enough to drink out of. :) - GMT830ExplorerIt's pretty comical how much effort people put into cleaning the black tank. Dump it only when it's full, no troubles.
- Gene_GinnyExplorer
BarneyS wrote:
That is the one I have been using too. I use it about twice a season so my tank monitors show the correct level twice a season.
... No need to spend $15-$20 for one. Here is the one we have been using for years....
Only word of caution, don't trust that plastic shutoff valve. I use a metal garden hose shutoff connected to it. - wanderingbobExplorer III have never understood why you feel that your black tank must be so dern clean .
This site has spent many ,many hours discussing this . Why must it be scrubbed out when dumping . I know not , but hurry up cause I have got to use it . - pitchExplorer IIAbsolutely are valuable when you need it. We never needed one,until we got a paper clog once. 3 minutes with the wand down the john and viola problem is flushed.
Like having a spare tire,90% of the time it just sits,but when you need it you need it. - ksbowmanExplorer III used one this winter in Texas on the "pyramid" and it was worth it's weight in gold when my stool was backing up into the bowl!
- 2012ColemanExplorer IIYes - they are. Buy a clear sewer elbow connection and you can see what color the water is that's coming out of the black tank. I bring a seperate hose to hook to the city water and wand my black tank out after every trip. It sometimes takes more than once to see non colored water(not brown).
- bsbeedubExplorer
IAMICHABOD wrote:
DatacomGuy wrote:
Camping world has a faucet connection kit.. $8 on sale.. Hooks the wand right up to the faucet, instead of running a hose around. Seems worth it.
Don't waste your time or money on this useless piece of junk.
I was given one and it was more than worthless,the sink faucet does not have the pressure to do any good with the wand.
While I can see your point, I disagree. When you are using the sink connection you also have to have the toilet valve open so you can insert the wand which causes an immediate drop in water volume and pressure. I installed a shut off valve in the line leading to the toilet and the pressure and volume returns making this item perfect for the job.
It was also the first time I ever used the tool to cut the plumbing in the TT. I was mildly nervous about it but it turned out to be a very simple job. - LynnmorExplorerAfter the junk Camco wand blew apart, and soaked everything, I built my own wand from CPVC. I used a washing machine hose that has a 90 degree bend on one end so that it can be easily attached to the sink faucet. Using the faucet allows hot water for better cleaning. To prevent back splash, I also added a large PVC end cap, with a hole drilled in the center, that adjusts to where it nearly touches the toilet.
- 1775ExplorerWe have the tank wand and even have the connection to attach it to the sink. First, the sink does not put out enough water pressure to really allow the wand do what it is supposed to do. My hope with the wand had been that for the first time since I got the RV new, I would see the black tank monitor read empty. That was a nice wish that never came true. I have used the tank wand a number of times dragging a garden hose inside the RV to the toilet and spending a good amount of time "cleaning" it. Maybe it is working but I have not really seen any difference than just filling the black tank with water after dumping (my tank is only ten gallons) and then running that through. My RV has a permanently built in macerator - no gravity feed and no ability to back flush the tank with any type of attachment. We carry the wand and the hose with us - just in case - but together they take up more room than they are worth in the limited space that we have in our Class B.
About RV Newbies
4,028 PostsLatest Activity: Mar 08, 2025
