Harvey51 wrote:
The trouble with the elbow on the end is that it won't fit into the slinky storage pipe. I guess you take it off for stowing? Does that wire clamp loosen/tighten conveniently? I have been putting the slinky is foot or two into the drain pipe. On two occasions the slinky slipped the clamp on the RV end and slunk down the drain. A wire with a hook bent on the end or a branch with a small branch sticking out works to recover the slinky.
NOPE mine fits just fine in my 5" fence post bumper ... It also fit in a 4" fence post pipe that I had before my current setup so the one I use will fit in the smaller storage pipes. In fact if you use the 5" fence post pipe you can even store the threaded step down fitting too. For the yellow fitting you just rotate it so it's in the angle portion of the storage pipe and then it fits just fine even in the 4" size pipe.
Larry
