Fixed Sight Training wrote:
NMDriver wrote:
C-Bears wrote:
I have the same truck. When we first went full time and started traveling I really felt the need to keep more fuel on board. I never really had the desire to make my capacity 70 to 80 gallons, but I investigated maybe adding another 25.
What it came down to for me was actual need. After the first several months (maybe 5,000 miles) of traveling I discovered that a 200 miles range, or about 3 hours was enough and I really didn't mind stopping for fuel. Actually we have found that we rarely, if ever, have to fuel more than once per day while pulling FW.
I have four 5-gallon diesel cans, but generally only carry three of them. They fit nicely in my bed tool box and are easy to pull out and refuel with. Depending on what part of the country we are traveling in, sometimes I have diesel in them and sometimes I don't. The point is, if I need to I can actually leave in the morning towing with as much as 46 gallons for a range of over 400 miles. Total cost of my "auxiliary" fuel supply was about $40.00 and that included aftermarket easy-pour spouts.
I know many RVers like the idea of hauling 70 - 100 gallons of fuel down the road. I have considered all the arguments of doing this, like being able to shop around for better diesel prices. But if I am hauling 500 - 700 pounds of extra weight down the road I am going to get less mpg, even though I may have just saved .10 a gallon filling up with that 100 gallons. Yes I have saved $10.00, but if I get 10mpg that day instead of 11mpg because of all that extra fuel weight, then I have used an extra 3 or 4 gallons to drive the same 400 miles. I spent about $15.00 to save $10.00.
In my mind if I spent several hundred dollars on an auxiliary tank I had better really need it plus I would want it to pay for itself in a couple of years.
Excellent analysis and I agree 100%
With respect your rig is probably well over 20k lbs. I don't think an extra 500 lbs are going to make a 1 mpg difference. Or any measurable difference.
It may or may not drop my MPG by one. I am just guessing that several hundred pounds would decrease my MPG. It would make sense to me that pulling up a grade with an extra 500 pounds would take more fuel, but maybe getting pushed back down the other side with an extra 500 pounds would make it up with better MPG?
I am one of those folks that ended up with a SRW 1-ton and a FW that has me right on my maximum weight limits, mainly on my drive axle. So no matter if I buy into the theory that a heavier unit uses more fuel or not, in my case I sure don't want to add any weight.
