valhalla360
Jan 05, 2021Navigator
Unless you get into small back roads, it's not an issue. 13.5ft is the standard clearance. If semis travel the road, you should be fine. Most low clearance bridges tend to be in the east in the older cities but even there they are pretty rare and well marked.
The bigger issue is campgrounds. They won't have low branches marked and since most RVs are 12ft or under, you will be the one testing for height.
About RV Newbies
