wa8yxm
Mar 20, 2023Explorer III
Is this a manual awning? On both the "House" and Roller ends somewhere there is supposed to be a screw that keeps the fabric from sliding front to rear (or side to side depending on how you look) good chance it's not there and the fabric has "Shifted" right or left a bit.. you may need to unlatch then on the ladder get a bit..er.. violent with a pry tool to start the arm loose (Caution damage can easily result) once its' out Inspect you may need to shift the fabric a bit (Lift the roller and work it like quarter inch) then see if it lines up better.
There are also other things that can shift a bit if not properly pinned and cause mis-alignment.
Recommendation is a professional if you are not comfortable I know a good one in the Flint. MI area (Assuming she's home from her Florida office where she winters) yes she is a she. She's good though.. I know a decent dealer/service center too also near Flint.
About RV Newbies
