Z-Peller
Mar 24, 2023Explorer
Start by opening clips on arms, then loosening knobs on arms, then release the roller with your rod, then pull lanyard out a few inches so roller unwinds slightly which will release tension, then give a good yank up on the lever on the bottom of each arm and the arm will come out of the designed notch at the top, and awning is now ready to pull rest of the way out……when putting awning away, let the last few inches go, so the arms slam hard and drop into the notch at the top, then you know the arms are locked in place.
Many awnings come open on the road because people don’t know those arms have a locking notch at the top and think it is just the roller tension holding it from deploying….Once you get your routine you will find it quite simple to do.
About RV Newbies
