gattorgetter's avatar
gattorgetter
Back to drawing board.... help me decide...
Looking for a RV, open to all options
Own 2011 GMC 1500 payload 1600lbs
Own 2016 GMC 2500 (gas) payload 2965
Toys: 2015 Lund Impact
Lang 60d 1500lbs/13ft in length no plate needed in MIch
Lang 36 hybrid 800lbs
Polaris Ranger Northstar 2000lbs add tracks for 2500lbs 13ft in length
Not all toys will go, smaller lang will always go
Year round use mostly in Michigan
Not hauling water
  • I don't think you have enough horse power to tow a toy hauler and the boat !
  • DrewE's avatar
    DrewE
    Explorer III
    Another possible option, perhaps from left field: a truck camper and a trailer as appropriate for the toy(s) du jour. You might (probably would) need a hitch extension and with it the corresponding reduction in towing capacity.
  • I don't understand what you're asking.
    You want to haul a 800lb Lang, had to look it up, 800lb BBQ for camping...... and? Something else at the same time?
    Want to use the pickup?
  • Well the good news is you can tow that boat behind a 5th wheel in Michigan if you have the Recreational R endorsement on your drivers license. You can not tow the boat behind a TT. So if your taking the boat you need a 5th wheel. Now the problem is finding a 5th wheel Toy Hauler to fit you, your family, your stuff and your toys into that doesn't exceed the payload rating of your 2500. Finding the 5th wheel is pretty much up to what you like and need.
    Oh, and one other thing, there is an overall length restriction but I don't off hand know what it is. So that pretty much is going to limit your 5th wheel size.
