Sandia_Man
Oct 17, 2017Explorer II
As stated above, your tow vehicle can provide a small charge to your RV's battery through the 7 pin connector, only way to know for sure is using a voltmeter on battery while tow vehicle is running, there should be a noticeable increase in voltage if a charge is present. Without an inverter your crockpot must be able to utilize 12 volts DC to actually function, they are available at Cabelas and Bed Bath and Beyond to name a couple of stores.
About RV Newbies
