RoyB
May 11, 2013Explorer III
The Champion 2000i will only put out around 1600WATTS or 13.3AMPS. So you can see having some of the larger current units "ON" will load it down it down pretty quick... You only have abit less than half of what the trailer can draw being a 30AMP system.
Here is simplified block diagram of a typical 30AMP trailer electrical system. Might help you see what else might be drawing high current. Seems like you can turn off ALL the 120VAC circuit breakers in the power distribution center and fire up the trailer using the generator. Then turn on each circuit breaker one at a time until it loads down...
Keep in mind the 2000i generator is not big enough to run your whole trailer with everything "ON"... Your generator only provides for 13.3AMPS or 16.7AMPS short.
Roy Ken
Roy Ken
About RV Newbies
4,032 PostsLatest Activity: May 30, 2015
