wa8yxm
May 11, 2013Explorer III
Shwthomas1975 wrote:
The knob has a gas, a 12v and an elec selection.
The water heater is propane too. The fridge is old and takes for ever to get cold, so I'm thinking that might be the cuplrit.
Yup, I've seen a few old ones like that.
RV absorption cooling uints (What the Fridge is properly called) do take forever to cool down, and they are energy hogs as well. Just so you know.
Go to your breaker box, One of them should be labeled CONV or CONVERTER, another is labeled MAIN.
Turn all off.. Then turn on MAIN, then CONV see if the gnnny overloads.
If you have 12 volt terminals/jacks on the Genny.. Forget those. ONLY connect the `120 volt to the RV.
Finally.. Some converters can suck a whole lot of power for a very short time, way beyond their rating... Kind of like motors. (only the reason is different).. What make and model converter, and what make and model power panel do you have?
About RV Newbies
4,032 PostsLatest Activity: May 30, 2015
