Shwthomas1975
May 15, 2013Explorer
Thanks again for all the replies. Sorry I was away for a bit.
Seems that if I plug in with all breakers on with the genny running on normal, not econ it's fine. I never thought of that. Thanks. I can then switch it to economy after it stabalizes then it goes right back down to idle and doesn't overload. Weird.......
Here is the info on the panel:
Todd Engineering LC30 120VLC/12VDC load center
PC30 Power source inverter
Also, do you guys and gals turn off the breakers when not in use? Only reason I ask, is I mustve left something on and the battery is now dead. If I turned them off religously that wouldn't have happened. I still have to do some research on what the breakers go to. One says micro, but I dont have a microwave. And thats the one that caused the genny to overload when started on economy.
Then there are 2 breakers on one for the main.
I'll get it all someday lol
About RV Newbies
4,032 PostsLatest Activity: May 30, 2015
