Shwthomas1975
May 18, 2013Explorer
I am at a loss.... Something occasionally is draining the battery. The bottom fuse marked front/micro is the culprit. Sometimes it will charger without overloading the genny with it on sometimes it won't. But sometimes the lights work with the breaker off and sometimes they don't. The fridge is on propane. The water heater is propane only. And the heat isn't on. Nothing should be draining or. If I toggle the breaker it spmetimes overloads the genny and sometimes it doesn't.. Any thoughts on what could be going on?
About RV Newbies
4,032 PostsLatest Activity: May 30, 2015
