westend
Jun 01, 2016Explorer
You should always have it on when towing. In case of an emergency break-away event, the trailer's brakes are activated by the battery.
As a precaution, you could wire the emergency brake switch around the disconnect. It won't use any power when not in use and will always be ready if you forget to turn the disconnect "On".
About RV Newbies
