leftys's avatar
leftys
Battery Life
Many posts advice you to use the battery disconnect switch to avoid battery drain while in storage. My question is, if my motorhome storage facility has power available does it make sense to keep the MH "plugged in" to keep the batteries charged? If so, do I keep the battery switch "ON"?
Thank you!
  • How long will it be left unattended in storage? Good batterys do not go dead in a month, even six months. Disconnected a fully charged battery bank in good condition will last many months with little discharge. Farm equipment, construction equipment, cars in storage lots, boats on moorings, all kinds of things are left for months at a time without access to power for battery minders & such with no ill effect on their batterys.
  • Thank you all so much for your input. I have a 2015 Feetwood Bounder but don't know what type of converter it has - I'll check and proceed according to your recommendations.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Depends on the converter/charger.. I have my choice of two
    Progressve Dyanmics Intella-Power 9180 with charge wizard
    and Xantrex prosine 2.0 (inverter/charger)
    Both of these are among the very best converter/chargers, in fact You will not find better ones, though for different reasons they are 3-stage converters with one additional outstanding feature (You will find several as good)
    IF I plug in and leave it for a year, with new GC-2 type batteries, I need to add distilled water (As they age I need to water them more often) That is with either of these 3 stage jobs.
    Some older trailers have the Magnetek 6300 line of power center/converters.
    This unit was designed back when the standard shore power was 110 or 115 volt, it uses a very poor method of voltage regulation so the modern 120 volt standard means it runs a bit "hot" (voltage wise not temp wise, a good regulator would get warmer (Temp) not higher voltage) so it can boil a set of flooded wet cells dry in just a week or two once they are fully charged, and this with only a few amps of current.
    So the answer to your question: It depends on your converter
    I gave you the best, and the worst, you need to find where yours is on the chart (less I named it) If you have an old 6300... Consider upgrading, pull it gut it (remove the electronics) and drop in a Progressive Intella-power 4600.. that is one of the many mentioned in the first converter description. (Functionally identical to what I have, likely a different last 2 digits).
  • Just this week I installed a Battery Tender to my house batteries. They were hooked up in parallel so I disconnected the main negative cable leaving the interconnected cables as they were. The Battery Tender will keep my batteries charged and will not boil them out. I also have a small Battery Tender hooked to the chassis battery.
  • When I had a Magnatek/Parallax converter, I wouldn't dare leave the battery on. Now that I have a Progressive Dynamics, I leave it on all the time.
  • Hi,
    It depends on which converter is in the RV. Do you know the make and model number?
  • I have a Battery Minder on my coach battery and a trickle charger on the chassis battery when in storage. I turn the battery switch off.
  • If you have a "smart" charger in your MH, you can leave it plugged in. If not, then you'll boil off your batteries.
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    I keep my trailer plugged in 24/7 to charge the batteries, and yes, the battery switch must be on.
