justin.powell wrote:
I have an issue on my 5th wheel with the batteries. I am green on this and at the risk of looking totally stupid I am asking what is wrong here. They are both 6 volt golf cart batteries which I believe are wired incorrectly. There is an onboard generator also on the RV. I have read to the converter and there is only 6 volts to it. The Generator does start wired as is. Not sure of the connections on the side and the toggle switch there also. I assume the toggle switch is something to do with the shore power. Any advice is greatly appreciated.
http://i153.photobucket.com/albums/s208/jkpowell/Slide1_zpszxaqbdfd.jpg
The golf cart batteries should be wired in series. So battery #1 ground is to the RV frame, while battery #2 - is connected to battery #1 +6 volts, and battery #2 + is now +12 volts above the RV frame ground wire.
Then the RV converter (45 amps at 12 volts) will charge the pair of batteries much faster than a normal car battery charger.
Good luck,
Fred.
