wa8yxm
Nov 14, 2015Explorer III
Golden_HVAC wrote:
Do you really want to pick up 200 pound batteries?.
Fred. Please do what I just did (read the spec sheet) 118 pounds.
Now I can pick up a 200 pound battery.. But I can not install it.
118 Pounds I also could not install on my battery tray due to it's location (I could if I cleaned things up a bit)
60 pounds is about my limite.
To the O/P. either configuration shoudl work wioth a 1500 watt inverter,, I recommend 200 amp hours per kilowatt. but 100 per kilowatt can do it,, Just not for long.. At 370 amp hours you'd be over 200 amp hours per kilowatt.. Two pair of T-105's (about 440 hours total) would be better. but not by much. Look into the cost.
About RV Newbies
4,032 PostsLatest Activity: May 30, 2015
