allen8106
Nov 27, 2015Explorer
Sambino wrote:
Hello all,
I'm slowly fixing up an old camper van that had all the electronics ripped out.
I'm looking at either two Trojan L16RE-B Batteries, or four Trojan T-105-RE Batteries. I'd rather get the two L16s, than the four T-105s, but I'm not sure how much power I could suck out of the L16s.
I'd like to be able to run a 1500W pure sine to power a 1500w toaster oven for up to half an hour. I know you need a pretty big battery bank to be able to run something that heavy duty. I was wondering if the L16s could do it, and if 4 105s could handle if the L16s probably couldn't. I figure the two sets in parallel would be able to up the amperage of the output, yeah?
Obviously I'd be using the thickest gauge wire I could get my hands on, and would have less than two feet between the batteries and the inverter. The batteries would be recharged with a 300-600w solar setup (if that matters), which is something I'm still figuring out as well.
Spec sheets for the batteries are here
L16- http://www.trojanbattery.com/pdf/datasheets/L16REB_TrojanRE_Data_Sheets.pdf
T105- http://www.trojanbattery.com/pdf/datasheets/T105RE_TrojanRE_Data_Sheets.pdf
Thanks in advance!
Handy Bob would tell you to stay away from L16`s as they have developed issues of some type which I cannot recall or find. I highly recommend reading hs solar blog, very enlightening.
About RV Newbies
4,032 PostsLatest Activity: May 30, 2015
