Sambino's avatar
Sambino
Battery Question -- 2xTrojan L16RE, 1500w Inverter?
Hello all,
I'm slowly fixing up an old camper van that had all the electronics ripped out.
I'm looking at either two Trojan L16RE-B Batteries, or four Trojan T-105-RE Batteries. I'd rather get the two L16s, than the four T-105s, but I'm not sure how much power I could suck out of the L16s.
I'd like to be able to run a 1500W pure sine to power a 1500w toaster oven for up to half an hour. I know you need a pretty big battery bank to be able to run something that heavy duty. I was wondering if the L16s could do it, and if 4 105s could handle if the L16s probably couldn't. I figure the two sets in parallel would be able to up the amperage of the output, yeah?
Obviously I'd be using the thickest gauge wire I could get my hands on, and would have less than two feet between the batteries and the inverter. The batteries would be recharged with a 300-600w solar setup (if that matters), which is something I'm still figuring out as well.
Spec sheets for the batteries are here
L16- http://www.trojanbattery.com/pdf/datasheets/L16REB_TrojanRE_Data_Sheets.pdf
T105- http://www.trojanbattery.com/pdf/datasheets/T105RE_TrojanRE_Data_Sheets.pdf
Thanks in advance!
  • Sambino wrote:
    I'd like to be able to run a 1500W pure sine to power a 1500w toaster oven for up to half an hour...
    With power usage like that, you may want to consider going 24v or higher. Deep and prolonged heavy amperage draws can heat things up(wires, batteries) after a while, no matter how big the wire is.
  • Both will require 14.8 daily charges but I understand the 16's have special charging considerations due to the height of the battery.
    300-600 solar may not be enough depending on all your other energy use. I would do an energy audit guesstimate. Number one is the question of if you ever want to run your ac. My answer was yes so I started with a 3000 watt Honda remote start generator. From there it seemed like the magnum inverter would have cost me $2,000 so I walk over and push the remote button for toaster, hair dryer, microwave. If you need silence than obviously you need to invert but it does get pricey to replace propane and avery small amount of gasoline.
    I have 4 cheap 6 volts and only invert to a 40 inch tv and misc laptop etc. Along with house furnace and everything else a minimum day uses 60 to 80 ah. A heavier day uses 120 or more.
    If you start out with 420 ah and can only use 210 at best and more likely say 190ish, in the end, with rain or clouds you could need a generator. I dont know your whole energy plan so just throwing some stuff out there.
    I'm running 520 watts with Bogart engineering solar. I know I couldn't invert much with these batteries. I like my digitally controlled house furnace and we cant tolerate a catalytic for our sinus headaches so furnace is 6 amps alone. The ultimate answer there is a CAT platinum vented. Next pack will be probably be 105's.
    Build carefully as there are many people out there that are way out of whack. 3 group batteries and a 2500 watt inverter!!!! or a 2500 watt inverter and 4 old gc2's but a 13.5 volt converter and 200 watts solar trying to bake cakes!!!!
  • My inverter is MSW as pure sine wave back in 1997 was over $3 per rated watt, and not nearly as energy efficient as today. So a 300 watt inverter was something like $900 back then. My 1,500 watt Trace M1512 inverter was $750 'on sale'. Back then a 75 watt solar panel was also very expensive at $375. Today you can get a framed 140 watt solar panel for $229 at the link provided above.
    Watch out for 'unframed' solar panels designed for mounting on homes, where the framework is installed on the roof, then panels mounted to that frame, then wired to the HOME, not a RV. Some of the frameless panels are $1 per rated watt or less. They do great at what they do, that is provide a 6 KW system for a home at the lowest possible cost and weight on the roof.
    Yes you can get by without a gas oven, by installing plenty of solar power. I have a toaster in my RV and it will draw 75 amps from the 12 volt battery bank. The 15 minutes it will cook will take 3 hours of full solar production to recharge my batteries. So cooking longer than 15 minutes is not practical, unless you have well over 500 watts of solar installed. Better to just fire up the generator if you will be running a 2000 watt convection oven to broil a steak for 30 minutes. . .
    Yes 4 golf cart batteries can supply 150 amps for 105 minutes (their full rating) and I have run my microwave for about 15 minutes (3-5 minutes at a time) from MSW inverter drawing 150 amps from the batteries. However it made the microwave cook so much slower that I had to replace it. Now I only run the micro on generator power.
    You might consider three inverters. I rarely run the big inverter while dry camping. It is not energy efficient at running just the TV set. I have a e-meter that carefully measures the amp draw out of the batteries and counts down what leaves, and what returns. My big inverter running a Direct TV receiver, the 19" tube TV and other loads in my RV might show a -8 amp total. If I shut off the Trace and plug in a 150 watt inverter, run the TV on that, total amp draw is dropped to about 6 amps. Saving 24 watts is important to me when I want to stay parked for a week at a time.
    The big pure sine wave inverter might have a larger than average standby amp draw, and say you have a 200 watt load, it might take say 240 watts input, or perhaps 275? While a 300 watt $35 MSW inverter might only have 220 watts input with a 200 watt load, due to it's much smaller capacitors, and transformers, ect.
    I have the small inverter plugged into a cigarette lighter receptacle that I installed next to the TV and VCR. The factory installed #8 wire to the TV antenna and near the VCR. It is fused at only 20 amps, but that fuse has never blown in 20 years!
    I have recommended people install a couple of cigarette lighter receptacles in their RV's with #10 wire and 20 amp fuse, using copper wire for supply and return to reduce voltage drop. I have run a dirt devil from the 150 watt inverter to clean up the old class C, and it worked fine. With the new class A, I would run the inverter/charger or 4 KW generator to run a larger home sized vacuum. It draws around 500 watts. . .
    There are not that many loads that require PSW. Microwaves should be included in them. So would a compressor motor, that requires high torque. Charging cell phones, laptops, and ink jet printers run fine on MSW. Laser printers require PSW.
    GOod luck with your system and have fun dry camping!
    FreeCampgrounds.com offers some great dry camping areas, many are free.
    Fred.
    PS: Yes L-16 batteries have been used in many home applications with 100+ amps draw from each battery. But I don't think they are as energy dense as the T-105 or T-125 battery. That is you get say 440 amp hours from a T-105 battery pack at say 275 pounds, while only about 350 AH from a similar weight L-16 battery bank.
    Personally I would avoid them at all costs due to their extreme weight. . . .
    You might want to look into the T-125 battery if you can find them for a good price locally. But also know that some say to avoid them due to the less water under the plates. Some state that you have about 1/2" under the t-105 battery plates for junk to accumulate before it will short out a cell. With more plate and less space under it, there is less room for the T-125 plate to accumulate junk before the cell is shorted out.
    Also some say that battery life of a L16 is less in home applications where the battery is not moved around. In a car, or RV, the battery is shaken on every move, agitating the plates, and fluffing off some 'stuff' that is not good for the plates, thus extending the battery life.
    Anyway my next set of batteries will be Trojan T-105 due to the 13 year battery life that I got from the first set in my motorhome.
  • Fantastic to know at least the 4 105s would work, but any clue how the unwieldy L16s would do with that kind of power draw?
    They do weigh a ton, no doubt, but I could struggle through moving them the few times I'd have to. The slight cost savings over the 105s would in my mind be worth the extra weight induced hassle.
    Thanks for the solar panel link, I'll be checking that out tomorrow!
    I have a propane stovetop, but no oven. I think the investment would be better spent in my situation towards more solar/inverter power considering my minimal oven use, but heavy electrical consumption.
    As for the MSW vs Pure, I'll need a pure for some other equipment, and it's looking like one big pure is ever so slightly cheaper than a big MSW and a small pure.
    Thanks for the speedy replies, loved the info.
  • DrewE's avatar
    DrewE
    Explorer III
    Most toaster ovens would be just fine with a MSW inverter. Heaters and switches don't care at all about the purity of the AC waveform. Even most with digital controls would probably work fine.
    I would note that one pound of propane has as much energy as a few hundred pounds of battery (though, of course, it requires a bit more specialized infrastructure to "recharge" a propane tank). In other words, for dry camping, a gas oven will cook a whole lot more than a toaster oven and a battery bank.
  • Do you really want to pick up 200 pound batteries?
    I can tell you first hand that moving out my old 4 golf cart batteries and installing 4 new 67 pound batteries wore me out, when I was only 40! I could not consider moving a 120 pound 8D battery anymore. Forget anything about the L16's. . They are just to heavy.
    I have a 1997 Trace M1512 inverter/charger in my 97 Bounder motorhome, with 4 golf cart batteries. It works out great. I also have 415 watts of solar.
    SunElec.com is a great place to look for solar panels.
    Fred.
