Gjac
Dec 14, 2014Explorer III
If you are trying to protect your tires from moisture, a material that does not absorb water is best. If you are trying to prevent the tires from sinking into the wet grass any material like wood , concrete, metal will work. I used 3/4 nylon 12"x 12" for the front and 12"x 24" for the rear tires, that act as a moisture barrier to preserve the rubber and also distribute the load so the tires don't sink into the grass.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
