kemeisland's avatar
kemeisland
Blew a fuse I cannot find... Bum,bum,bum.
First time poster, planning to be pretty active on this forum. Hello!
I searched for this in the existing posts and haven't found anything.
I have my first RV, testing out the full-time life. Bought an '89 Mallard ( M-270 SB-Ford, on an Econoline 350 chassis ). Everything has been pretty good once I got the RV into shape to begin with. I'm the third owner in 25 years.
Today I had a space heater and electric water kettle on the same circuit and I heard the fuse blow. Usually I take one or the other off and use one at a time. This time that didn't happen. Now all the outlets aren't working. I checked the fuse box at the back under the closet, close to where the power hookup comes in for 30 AMP, but none of the fuses are blown. I was aware a fuse might not look blown but still be blown, so I took one I knew worked and tried it on all the other spots, with an outlet tester plugged in to see if it lit up. None of the fuses seemed to affect it.
Where do I go from here? Is there somewhere else a fuse box might be, or a specific fuse for the outlets only? Right now I've put the space heater and my laptop on the separate circuit the microwave has, but that's not a solution and I'll need to be extra careful not to blow my only remaining outlet. I'm hoping there's easy access to some magic fuse.
Any wise full-timers or electrical magicians have any ideas?
Thanks in advance for any help you can give me!
  • Have you checked the GFI outlet. That may need to be reset
