jarata1ExplorerOct 10, 2017Breakers OffIm done winterizing and getting set to cover and store my 16 ft travel trailer my question is should I shut off the breakers for the winter
Boon_DockerExplorer IIIOct 10, 2017Fully charge the battery/s to 100% then remove the positive or negative cable off the battery. Remove a cable even if there is a disconnect switch. A lot of the time the disconnect does not disconnect everything.
