Atlee
Jan 21, 2018Explorer II
As far as I know, there's nothing to be concerned about. What you do need to note is how far the two black tanks are from each other. Usually in a set up that has two bathrooms, there are two black tanks, which means after dumping blac and gray tank, you have to move the stinky slinky to the other black and gray tank outlet.
6door74 wrote:2gypsies wrote:DutchmenSport wrote:
If getting that half bath camper, take an extra minute to consider where the black tank values and outlets are located. Really, check it out.
... and how far the black water has to travel to exit.
What exactly should i be looking for or concerned about?
About RV Newbies
