mattbatson
Jul 24, 2016Explorer
Sport45 wrote:
Be careful with that "little homemade septic system" you're digging. If not designed just right it can become a real headache if not a liability. I'd let the gray water flow freely in order to keep the bugs alive. The difficulty will be in sizing things to work with a very small amount of regular inflow but still be able to handle 60 gallon flushes without surging scum into your field lines.
Yes, gray water was going to flow freely
It is a homemade system using two 50 gal rain barrels, one set slightly lower underground then the other, connected to each other with pvc pipe near top...it is a design I found on a homesteader/survival site I used to frequent
About RV Newbies
