mattbatson
Jul 25, 2016Explorer
coolmom42 wrote:
I think you should consider a composting toilet to deal with your black waste. Tee into the home's existing system for your gray water. This will avoid a lot of pluggage problems.
One consideration is the electric panel. You will need at least a 30 amp/120 V connection, and if your trailer needs 2 AC units to cool it, you will need a 50 amp/120 V supply. So somewhere in the electric panel there needs to be enough available circuits to supply the current. Definitely get a licensed electrician to hook this up and be very clear on the power supply and the type of outlet you need.
I will consider a composting toilet for sure.
she has a 200 amp panel will plenty of room to spare...the big thing is it is about 150 ft from where the hookup's will be
About RV Newbies
