dirtywhiteboy wrote:
Thanks so much for all of the replies. Where can I find the rated axles lbs? I bought this used and not much info from seller. It has E rated tires on it now. It is a 35' Fleetwood 5th wheel gvwr 14,000. Can't get any info from Fleetwood since they stopped making them.
Again thanks for ALL the info for a rookie 5er.
With a GVW of 14,000#, odds are you have 6,000# weight rated axles. (approx. pin weight of 2800# sets in the bed of the truck), leaving 11,200# on the axles..."E" rated tires souldn right .I'd still highly recommend the Michelin XPS RIBS, though there are probably others to be recommended that wouldn't be as pricey.
