ppine
Sep 04, 2020Explorer III
I used to sleep in the back of my truck in Colorado at ski areas when it was well below zero. The first thing you need are some good down sleeping bags.
You can run some heat if you have power, but try for a temp like 50.
The simplest way to run the plumbing is to winterize it and work around it, but some people like to use everything no matter what. Get some heat tape, seal up under your rig,
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
