valhalla360
Aug 06, 2018Navigator
You need more battery storage.
- 1 hr or solar won't solve your problem.
Once you have enough battery, the generator for an hour is very much viable but you won't get to 100%.
Your charging system might put out 40amp-12v but once the batteries get around 80-90% full, they rapidly taper down in terms of how many amps they will absorb. At the same time dropping the batteries below 50% charge damages them. So figure your capacity as around 30-40% of the rating (50% charged to 80-90%).
Take the items that you will run and calculate how many amps each draws and how many hours you want them to run. Your storage capacity should exceed that.
About RV Newbies
