valhalla360
Aug 06, 2018Navigator
mowermech wrote:
Another possibility is to buy a high output (not one of the little 6 amp units) battery charger, hook it to your house battery and plug it in while running the generator for an hour or two.
More batteries will help last overnight, but the re-charging problem remains the same.
Actually a larger bank really helps out because it can absorb greater amps.
If your batteries are only absorbing 10amps from the 40amp charger...adding a 6amp second charge won't gain you anything.
About RV Newbies
