Fresno_Tundra_D
Aug 06, 2018Explorer
heyobie wrote:
Where do you use Coleman sportcat? It seems so small. I assume you place it in the bedroom.
Last year I used the kitchen stove to take the bite out of the air.
Does anyone use kerosene heaters. I have a large one I used to use to heat my daughter's grooming shop. It can heat.
We put it in the kitchen area below our bedroom in our fifth wheel. Too worried that blankets during the night would touch the heater to use in our bedroom. We really only use it when camping during spring break in Yosemite and it doesn’t make a ton of difference but it helps. If the outside temperature gets down to low to mid 30’s, inside it will stay about 10 degrees warmer(43-45) with the heater as opposed to around 38-40 without. That’s why extra blankets are a must. But if I’m dry camping a week and have limited generator hours I can make it no problem. In the morning when I wake up I turn the heater blower on with the generator going to heat up the RV for about 15-20 min.
About RV Newbies
