Rvbewbie101's avatar
Rvbewbie101
Can I tow this TT with my 5.7l v8 Durango
Hello
First of all I am a complete newbie when it comes to rv’a. I did a little research and I think I found a TT that works with my Durango and family.
Durango specs:
5.7 l v8 pulling power 7200
Payload is roughy 1600lbs
Unibody frame
Tow package installed by manufacturer with class iv
TT specs:
https://www.rvtravelworld.com/product/new-2019-highland-ridge-rv-mesa-ridge-conventional-mr180bhs-992511-29
Highland ridge Mesa ridge 180bhs
Length is 22 feet
Gross weight is 4950 lbs
48gals water storage
Not sure if one or two 30lb propane tanks
TW = 594lb ( 4950 x 12%)
Should give me plenty of payload room still
Another question is on the actual hitch, what would be a good WD hitch
Let me know if this works, thanks
  • It looks reasonable if the Durango isn't loaded down with coolers, luggage and tools in the back. Make sure you have properly rated tires in the Durango that meet the OE specifications. Often times we shop for tires based on looks when we don't tow ;)
  • drsteve wrote:
    It looks OK, but a bit limited on cargo. 600 lb of tongue weight plus you and the family is going to probably be close to the Durango's limit. You will probably want to tow with an empty fresh water tank, since 400 lb of water would represent almost half of the TT's cargo capacity. As long as you don't try to bring too much stuff, you should be fine.
    How much family are we talking?
    I was wondering if I should calculate the water weight into the payload equation since I Calculate the tongue weight using the gvwr of the trailer . What do you think?
    For the family, as of now it is 3 of us, roughly 400lbs.
  • It looks OK, but a bit limited on cargo. 600 lb of tongue weight plus you and the family is going to probably be close to the Durango's limit. You will probably want to tow with an empty fresh water tank, since 400 lb of water would represent almost half of the TT's cargo capacity. As long as you don't try to bring too much stuff, you should be fine.
