CharlesinGA
Jan 24, 2018Explorer
In RV parks with shore power your fridge should be on 120V anyhow, and cooking on the grill, and for that matter on a picnic table using a electric hot plate is, to me, nicer than cooking on the stove inside. The hot plate uses the CG power but gets you outside, and you also should have one of those $20 Korean butane burner hotplates, and they are good to cook on the picnic table with. I don't want to smell up and grease up the inside of the MH.
Long story short, you may not use much propane at all, unless you are in cold weather and need the furnace. Again, if in a park with power, use their power to run the heat pump if you have one, or run an electric space heater. Saves your money and gas.
Charles
Charles
About RV Newbies
