DrewE
Jan 25, 2018Explorer III
swiftboot22 wrote:
I think it is proper procedure for the propane supplier to turn off your onboard tank to insure no open flame in coach. They almost always forget to turn it back on afterwards, you should check before getting underway.
That is standard procedure, but you should also turn off appliances (like the fridge) manually. The electronic igniter systems don't know the propane is shut off at the tank, and if they want to light they'll spark and retry a few times at intervals. Similarly, the generator and main engine need to be turned off as well.
About RV Newbies
