frankdamp wrote:
Since the wheels on the Mini are so close to the corners, I wouldn't have expected a dolly to be a risk. Also, it might be light enough not to need auxiliary brakes, but that depends on the weight of your Class C compared to the added weight of the Mini.
A friend tows a CRV 4-down behind his 40' DP and hasn't added aux brakes to it.
some states require rear lighting to be within X feet of the rear of vehicle. the mini would exceed that distance if you didn't have aux lighting. the owner's manual gives instructions for towing it 4 down??
bumpy
