Chaz59 wrote:
can i dump a half gallon of vinegar in black tank and let it sit overnite when i return home for a deodorant, then dump, or do yall have a better way to freshen tank. Also what do you clean the toilet bowl and also the cavity under the toilet before it goes in the tank. thanks
AS for the cleaning, we use the same cleaners as at home. The only thing to avoid is any harsh abrasives (esp powders) as that messes up the seals.
After dumping we will use our blank tank flush to get any extras out, although I probably only do this every 3rd time or so.
Then, every time, once empty, I'll have someone hold the toilet flush open and count to 45. Count time may vary but in our unit that will put about 3-4 gallons in the tank to prime things!
Finally, we do use the drop in deodorizer packets but to be honest, its really just to make our ladies happy ;) I don't think it really makes any difference if things are working correctly.
As long as someone doesn't flush while the fan is on, we don't get any odor.
