Beauty7's avatar
Beauty7
CO2 detector going off from??toilet gas??
We have a brand new (only 2 weeks) travel trailer-2017 Coachman Apex Ultralite 300bhs. We are also brand new RV'ers.
A few days after being in it, (we still are), we turned the fan on in the bathroom, and the CO2/propane detector went off full blast continuous beeps. (We DID NOT flush the toilet with the fan on). We re-set and fanned it to get whatever "smell" it might be detecting away, it finally stopped. This happened several more times. (Upon reading the pamphlet with it, we found it was installed, ankle height, only 8 inches away from the bathroom door, when the recommendation is 4 feet from any doors.) Does that make sense? Is that normal installation for a CO2 detector to be installed near the floor THAT close to the bathroom and any possible gases that may waft out?
Also during this time (this past Weds), we discovered after cleaning out the black tank, that we left it accidently open for 1 1/2 days (uggh) and had a not so lovely stench wafting through our place for a few days (yes-paranoid now about closing it, but complete lesson learned).
We gave a thorough cleaning, filling, rinsing, and bought Rid-X for the black tank thinking that would stop the weird, fan/CO2 beeper action.
Fast forward to today, Sat., 430am of course, we get woke up to the CO2/propane detector beeping full force. This time no fanning in the world made it stop. We did what everything says to do-open all windows, turned off propane, and call the fire dept. It DID stop then. They came, checked for leaks with their gadget that read 0 the whole time they said, and concluded it must be a faulty CO2 sensor.
Of course 10-15 mins after they left and we started closing windows, it crazily went off again. Now confident there are no leaks, we took out the fuse to get some peace. I know this is NOT the solution.
It is a Saf-t-Alert (MTI Industries) alarm. Is that even a good brand?
Any insights? Toilet gas? Bad placement? I have read other posts that have said to replace the alarm with a different one. Is that more feasible than having the company or my dealer who is 90 miles away (under warranty) replace me with a new one? IS there a "better" brand because now I'm leery of what I've got! Any help would be appreciated.
  • #1 cause is low battery.
    check the battery with a hydrometer or multimeter.
  • TomBird wrote:
    Battery getting low??
    x2 on this...or some other DC electrical problem. Many of these detectors are sensitive to low voltage (perhaps not by design). Having it go off when you turn on the fan would very much correlate with that, as the fan uses a reasonable amount of power and thus can drag the voltage of the system down a little...or even more than a little if the battery is not up to snuff.
    Incidentally, you have a CO detector, not a CO2 detector. They are quite different gasses.
  • Any aerosol, like hair spray, deodorants, even solid deodorants can give off enough hydrocarbons to trip a co detector. At night, the outgassing from deodorizers could be enough to set off your co detector.
    Do you have any of those ?
  • 1. Bad placement.
    2. Possible off gassing from building materials (think foam in couch, bed, glue from assembly, the list is endless. It WILL go away eventually.
    3. Units DO go bad, even when they're brand new. Remember the RV industry uses the CHEAPEST parts they can get. Got to an RV supply store and get a replacement.
  • I've had dog farts set mine off, so I guess toilet gas could it too.
    BTW itit's CO carbon monoxide detector the poison gas, not CO2, like bubbles in beer.
    To double check your detector you can get another at Walmart and return it if you don't need it.
