timmac
Apr 29, 2016Explorer
trey.a wrote:
Thank you all for the replies.
With that, I will start looking at travel trailers. I have a truck that can pull a trailer, and F150. We also own a Tahoe, although its towing capacity is less. Ideally, I would need to stay under 5000lbs wet. This gives me the option of using either vehicle when needed. So, I will start looking in that area.
I had a half ton short bed truck and bought a 27 foot travel trailer weighting around 6000 lbs and the truck seemed to weak in both the suspension and brakes had to upgrade to a 3/4 ton, yes with a half ton you want your max to be 5000 lbs, anymore than you will be replacing the truck..
About RV Newbies
4,032 PostsLatest Activity: Dec 23, 2025
