garyemunson wrote:
This year has seen an explosion of RV sales with a lot of first-timers buying RVs. There's been a lot of people posting their discontent with things breaking and falling off and complaining about poor quality in general. People need to keep in mind that you are in effect dragging your house down the road submitting it to constant shaking. When not in use it bakes in the sun and freezes without heat. When you buy an RV, you better be prepared to babysit your RV coach as long as you own it. You need screwdrivers to fit whatever type fasteners hold it together and regularly spend time retightening them. They WILL get loose. Trim is going to fall off so small tacks and Liquid Nails will be your friend. It will be much better for your blood pressure to just take care of the little stuff on your own (even if you are still under warranty). How much is your time worth taking the rig to the dealer then having to return later to pick it back up? The upside to this is you will learn a lot about your possession and minor issue on the road can be quickly taken care of with your acquired knowledge. Leave the big stuff to the pros but get proficient at taking care of the small problems (because you will have plenty of them).
And thats one reason I built my own TC instead,,
Plus no one makes anything as aerodynamic and well insulated,,
R-10 rigid foam everywhere..
Simple plywood glued together and nothing came loose yet in all these years,
,if I can do it why cant RV builders?
