BarryG20
Jul 29, 2019Explorer
You will get two answers. As you stated max psi stated on the tire or the trailer placard which is more then likely max psi on the tire sidewall for the oem tires.
The other answer is weigh the rig and set the psi per the tire manufacturers load inflation table for that tire. which may or may not be the max psi on the tire sidewall that will depend on the weight they are carrying.
Personally (and I have upgraded the tires on my trailer to a higher load rated tire than came oem) I go by the load inflation tables based on the weight of the axles and I add extra for an additional safety margin.
My trailer came with Ranier 225/75/16 load range d tires with a max load of 2540 at 65psi, my new tires well at the time new were load range e with a max load of 3420. Even at 65 psi (same psi as the max on the oem tires and trailer placard) have a load rating of 3000lbs substantially higher load at the same psi rating. My trailer axles weigh in around 7900lbs for both axles for how I load the trailer so for easy rounding lets say 2000lbs per tire and according to Goodyear's table I can run that at 35psi for a load of 2020lbs. Which is not enough margin for me so I run them at 55 to 60psi which is 2730-2870 worth of load well above the oem tires load of 2540 at 65psi. I get a better ride at the lower psi and still a larger load margin so win win for me in my mind. I am sure someone will tell me I'm an idiot for not running the max 80psi on my (new) tires. However I trust the tire manufacturers knowledge of their tires much more than the trailer manufacturer who does not make or engineer tires.
About RV Newbies
