spoon059
Jul 29, 2019Explorer III
Tires disintegrate faster due to heat. Heat occurs when you have flex in your sidewall. Some flex is necessary, but excessive flex leads to increased heat which leads to increased chance of tire failure.
I buy trailer tires that are rated much higher than I need them. Then I keep those tires inflated for their maximum weight carrying capabilities. When I check my tire and hub temps at fuel stops, they are usually just a little hotter than ambient temps. That is my objective.
About RV Newbies
