BB_TX
Jul 29, 2019Nomad
Even tire different manufacturer web sites don’t agree. Some provide recommended tire inflation charts based on loading. And from a maximum rubber to road contact viewpoint, and therefore maximum traction, that certainly makes sense. But it also means you have to know the weight on each tire. Other sites simply say inflate to the max pressure as stated on the sidewall. That is probably the safest approach, and certainly the easiest. Downside is that if the weight on the tire is far less than the max load rating, there would less rubber contact to the road as the tire tread would be more rounded, the tire may wear faster in the center of the tread, and the ride could be harsher due to the tire being harder.
Take your pick.
Take your pick.
About RV Newbies
