wa8yxm
Jul 30, 2019Explorer III
rvshrinker wrote:
Everything I read says tires should be inflated to Max psi. Is there general agreement on that? I plan to do whatever is safest and as of last evening, my tires are at 60 and Max is 80, so I have some filling to do.
Strange. this is the first time I have read that.. I've always read tire inflation should be adjusted by scaling the wheels (each wheel (not tire but wheel) and adjust per weight on the wheel.
THe tire does not say "Maximum Pressure XX PSI"
It says "Maximum load yyyy pounds at maximum pressure of xx PSI"
About RV Newbies
