RoyB
Jul 22, 2013Explorer III
Most often when a deep cycle battery gets discharged below 50% charge (apprx 12.0VDC) and do not get re-charged back up right away they will start self destruct inside the battery...
You need to have a multimeter reading the battery terminals when you are charging as also sometime when a battery is really low the battery charger will kick off and not keep appling DC charging voltages. Sometimes this has happened to me and I had to start out with a lower charging setting (like maybe 2AMPS) and sort of work my way up in small steps to keep the charger from kicking off.
A couple of weeks of trailer lights left turned ON is probably a death warrant for your two 6V batteries. When all re-chargiing fails of course take them back and maybe you can work out a replacement deal with costco. They sell alot of Golf Cart batteries... I don't believe they are at fault however based on your failure description.
Try lower charging setting and use a multimeter across the battery terminals and make sure it stays in charge mode for a couple of hours and hopefully the batteries will start returning to normal... I don't know anything about our brnd of charger but it would probably work better if you could each 6V battery separately. DO NOT however apply 12VDC to the 6VDC battery terminals. I think about 7.5VDC is the norm charging voltage...
Like they always told me at work when I did something like this... "Bend over Braddy" and then each fellow technician gets a free boot shot...
Let us all know how you making out... Those GC2 Golf Cart batteries are built to withstand alot of punishment...
Roy Ken
Roy Ken
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
