Bumpyroad
Aug 05, 2013Explorer
havasu wrote:
The other issue is how heavy your RV will be - typically a 40' diesel will require a special license in many States - under 26,000lbs then all States will let you use a regular car license. The special (non CDL) test is another complication you can do without.
Keep the questions coming - happy to help!
also, some states, IIRC CA for example, have special requirements for over 40 ft. so in addition to weight keep length in mine. of course I doubt any 41 ft Class A would sneak under 26,000 lbs. :)
bumpy
About RV Newbies
4,032 PostsLatest Activity: May 30, 2015
