aftermath
Jun 10, 2023Explorer III
TheOne,
Ok, here are some ideas for you to think about. If your trailer has been winterized then I am assuming that you have the pink stuff in all of your lines. I also will assume that your hot water tank has been by passed. You don't want to put antifreeze in the hot water tank.
To dewinterize I suggest that you hookup your city water to the proper connection. Use this to "clear" out all of your lines of the pink stuff. When you have done this, open the bypass valves and fill the hot water tank. Leave a hot water faucet open so the water can fill up the tank and the lines. When all of this is done, disconnect the city water, fill the Fresh water tank and turn on the pump. Others have suggested that the valve that allowed the pink stuff to be pumped into your system needs to be closed. Once everything is flowing you are ready. Wait, you should go back and sanitize the entire system. You can google this to find out how.....Good Luck.
About RV Newbies
